RPM +2 Front Suspension Mount for the Redcat Lowrider – Classic Camber Style!
RPM #72052 - 2 Front Suspension Mount for the Redcat Lowrider
RPM just dropped a killer new upgrade for your Redcat Lowrider – the +2 Front Suspension Mount, and it’s all about attitude. If you love that authentic “hoppin’ hydro” vibe, this part delivers the look in true lowrider fashion.
On a real lowrider, “+2” means the upper A-arms are extended by two inches. Scaled down to 1/10 RC size, that’s +0.2” (5.08mm). But instead of stretching arms, RPM re-engineered the suspension geometry to get that classic positive camber look. The result? A dramatic 10° camber shift – from -2° stock to +8° with the new mount. It’s the kind of stance that turns heads every time you lift the body.
To keep things driving as good as they look, RPM includes a replacement steering center link that corrects toe angles back to factory spec. Testers say the handling feels even better than stock – smooth, responsive, and dialed in.
Like all RPM gear, the +2 Front Suspension Mount is Made in the USA and backed by their limited lifetime warranty. It fits Redcat’s FIFTYNINE, SixtyThree, SixtyFour, and SixtyFive models. It also fits the Caprice Classic chassis, though body clearance is tight, so RPM doesn’t recommend it there.
If you’re chasing that perfect lowrider stance with unbeatable durability, RPM’s got you covered. Check out more from RPM
Product Information
Part Number: #72052 - +2 Front Suspension Mount for the Redcat Lowrider
MSRP: $16.95
