Proline Ridge-Line Bumper Set
Proline Racing Ridge–Line Heavy Duty Bumpers are manufactured with the Scale Crawler enthusiast in mind. The 6088-00 bumper kit comes with 5mm LED Light mounting points as well as dual tow points. The 6089-00 bumper kit comes with 3mm and 5mm LED Light mounting points as well as dual tow points. There’s also realistically simulated roller fairlead along with several mounting points for can lights or other scale accessories. Access ports through the bumper and brackets allow for behind bumper mounting of real scale working winches (Not Included).
The 6088-00 Narrow kit will fit narrow crawler bodies up to 5.750″ wide or you can trim the ends to accommodate bodies over 6” wide. If you want to go W I D E then see #6089-00 Wide Kit.
The 6089-00 Wide kit will fit Truck / crawler bodies up to 7.5″ wide or you can trim the ends to accommodate bodies over 8” wide. If you want to go Narrow then check out the #6088-00 Narrow Kit.
Proline Ridge-line bumper installed
Part #: 6099-00 – Proline Wide Set for SCX10, REVO, Summit & T/E MAXX.
Part #: 6098-00 – Proline Narrow Set for Axial Wraith (Front Only), SCX10 w/Narrow Bodies, REVO, Summit & T/E MAXX w/Narrow Width Bodies.
