Castle Creations has teamed up with Hobbico to create the new Mamba Max Pro Short Course Truck ESC and Neu-Castle 2400kv motor combo to R/Cer’s who want to take the next step in speed and reliability beyond their stock brushless setup.
The included wires and the direct fit bolt in Neu-Castle 1415 (2400kv) motor makes the Mamba Max Pro Short Course Truck Edition Combo easy to install. Just add your battery connector to the ESC and you are ready to go!
Castle Creations suggests using the Mamba Max Pro Short Course Truck Edition Combo with 1/10th 2wd and 4wd vehicless weighing 6.5lbs or less ready to run with batteries installed, up to 4S max. Also don’t forget, this is a 4 pole motor, so you can gear it higher than 2 pole motors of higher KV.
Mamba Max Pro SCT combo includes
- Mamba Max Pro SCT Edition ESC
- Neu-Castle 1415 2400 kv motor
- CC Blower fan shroud
Part #: 010-0091-00 -Mamba Max Pro Short Course Truck Edition Combo with 2400kv motor
MSRP: $240.00
