The Team Losi LST2 uses similar, although a slightly wider outer hinge pin mount than the original LST. RPM's LST2 A-arm adapter kit makes up that difference and allows you to use RPM's ultra-durable LST A-arms (#73192 – black & #73195 – blue) to mount to the Team Losi LST2. This kit, combined with RPM adjustable A-arms, allows any LST2 owner the luxury of adjustable camber, not presently available on the stock LST2.
This adapter kit includes 16 black molded nylon spacers (enough to complete all four corners of the truck) that fit perfectly when adapting RPM LST A-arms on the newer LST2. The conversion is as simple as removing the stock Losi A-arms from the LST2, installing a set of RPM LST A-arms, and placing one spacer off to either side of the A-arm at the upright.
Tech Note: RPM recommends that this kit be used in conjunction with RPM LST A-arms only – part #73192 & #73195 (sold separately).
Suggested Retail Price: $4.95 / set of 16
Make your comments about this new kit from RPM on our Losi LST Talk forum!
