HPI RTR Sprint 2 Drift
HPI Sprint 2 Drift
New from HPI Racing is the 1/10th scale RTR Sprint 2 Drift. The HPI RTR Sprint 2 Drift is electric powered for clean and quiet indoor or outdoor drifting. Based on the popular and durable Sprint 2, this drift version adds specially designed hard compound drift tires pre-mounted on officially licensed replicas of the famous Volk TE37 wheels. Top it off with your choice of two different clear body shells, the legendary Toyota Trueno AE86 or the Nissan 350Z, both supplied with pre-cut vinyl decals and an extra set of drift decals. The chassis is factory assembled right out of the box, making the Sprint 2 Drift the quick and easy way to practice your drifting skills. The HPI RTR Sprint 2 Drift is a complete drift machine that looks and drifts just like the real thing.
The HPI RTR Sprint 2 Drift chassis is 4WD for consistent drift action on a wide variety of surfaces, easy to drive, and has all of the features you need to adjust for a perfect drift set-up: camber, toe-in, ride height, Ackerman, and a wide variety of available shock oils and shock springs! With a big foam front bumper, reinforced molded nylon chassis, upper deck and shock towers, you'll see that the Sprint 2 Drift can easily take the abuse of drift driving. The full ball bearing, dual belt, 4 wheel drive transmission is very efficient and capable of handling high power modified electric motors down to 10 turns. Standard equipment includes a 17 turn motor, reversible electronic speed control, battery pack, AC charger, and a highly quality HPI TF-1 radio system. And it’s all pre-built to precise factory specs to get you drifting quickly, just paint and sticker the body, charge up the battery pack, install AA batteries in the transmitter, and you’re ready to start drifting!
HPI Sprint 2 Drift Features:
  • The included 190mm body is clear, pre-trimmed and ready for your custom paint scheme. Realistic vinyl decals are supplied and pre-cut for easy application. Convenient window masks and protective film are also included.
  • High quality Nosram Reversible ESC, motor and battery pack included.
  • Officially licensed Rays/Volk TE37 chrome plated wheels. 6mm offset rear wheels fill out the fenders and give the wheels the wide look seen on full-size drift cars.
  • Hard compound Type A drift tires for controllable drifting with realistic looks and aggressive tread pattern.
  • Foam bumper protects the car from potentially damaging impacts.
  • Adjustable rear body posts allow you to mount a variety of different bodies without trimming or replacing the posts.
  • Fine tune your suspension with adjustable turnbuckles.
  • Complete set of ball bearings for a smooth and efficient drivetrain.
  • Oil-filled coil-over shock absorbers with specially chosen springs for drifting.
  • 2 degree and 3 degree rear hubs for additional tuning choices.
  • Durable injected molded nylon main chassis.
  • Front and rear shock towers with optimized shock absorber and camber link positions for ideal suspension geometry.
  • Optional low profile front shock tower is included in the kit which allows the use of the full range of HPI 190mm bodies.
  • Droop screws allow you to “race tune” your suspension settings.
  • Precise bellcrank steering.
HPI Sprint 2 Chassis
HPI Sprint 2 Drift Specifications:
  • Length 17” (431mm)
  • Height 5” (127mm)
  • Width 7.5” (190mm)
  • Wheelbase 10″ (254mm)
Part #: 750 – RTR SPRINT 2 DRIFT WITH TOYOTA SPRINTER TRUENO BODY
MSRP: $429.00
Come discuss the new HPI Sprint 2 Drift in our General RC Electric Talk forum!
