The HPI Mini Recon is the perfect 1/18th scale fun package. Made from extremely tough composite material the HPI Mini Recon is nearly indestructible. The HPI Mini Recon features a powerful 370 size motor that accelerates the Mini Recon to incredible top speeds. The Mini Recon comes as a true RTR package with absolutely everything you need to get going, including: HPI TF-40 radio set, 7.2V NiMh battery, charger and even AA batteries for the transmitter!
HPI Mini Recon Features
- HPI tf-40 2.4ghz radio set for trouble free control.
- Heavy-duty 4wd shaft drive system to handle the high torque rm-18 motor power.
- RSC-18 electronic speed controller
- RM-18 high torque motor
- Super smooth ball differentials provide reliable power transfer.
- Fully independent double wishbone suspension.
- 4 factory fitted long-stroke oil-filled shock absorbers soak up all terrain.
- Twin point steering with integrated servo saver.
- Covered battery for extra protection.
- Full ball bearings
- Strong molded composite tub chassis, shock towers and suspension parts make the car nearly indestructible.
- Pre-glued high grip "micro block" tires on chrome 6 spoke rims.
- Pre-finished and trimmed bodyshell, fully finished from factory with applied decals.
Mini Recon Specifications
- CHASSIS LENGTH: 232mm
- WIDTH: 174mm
- HEIGHT: 108mm
- TRACK: 145mm
- WHEELBASE: 160mm
- DRIVE SYSTEM: Shaft 4WD
- TIRES: Micro Block
Part #: 105502 – HPI Mini Recon RTR 1/18th truck
MSRP: 179.00
Discuss the HPI Mini Recon RTR 1/18th truck in our Mini and Micro scale RC forum.
