Hi -
I finally received my sts .28 engine back from the stockist as it originally had a faulty front bearing and wouldn't run. It finally idles, however during its first tank it started to run way too hot (it was still steadily climbing through 260 deg F) when I shut it down as I was afraid it would start to damage itself. The manual says I should be aiming for 210 deg F. I'm pretty sure I had it running nice and rich - there was smoke and fuel spitting from the pipe. The only thing I noticed is that it was idling too high. I tried to use the manual to find the idle air screw (which apparently controls the idle rpm), but it is only pointed out in exploded view - I can't find the thing on the actual engine (newbie I know). Is it possible it was running too hot as it was idling too high? It was revving high enough to just start to engage my four shoe clutch.
Is anyone familiar with the idle control for this engine? Also, is there any other reason why it could have been running too hot?
Thanks
Chris.
Thanks
Chris.
