this is what i found over on rctech
Talking mine
I have 4 24.7 motors 3 pro's and 1 regular. I won't settle for anything less for what I do than a 24.7! My settings are 3.25 turns out on the high speed needle, and make the low speed needle flush with the inside flange on the carb slider. don't screw the low speed needle in! you will ruin the needle in the carb, just make sure the screw head is flush with the inside wall/flange.
BTW. I have a 24.7 pro motor that I have run 11 gallons of fuel through and still have good compression! These things are a beast for reliability! Good luck.
