xtm 24.7 motor problem
spyhunter48
Gone - bye bye.
hi i have a xtm 24.7 that i just rebuilt it runs really good .. but the pull start rope keeps staying out....do you have any way? :cheers:
ok where can i get 1.. a lot of hobby shop dont carry xtm....
and how did i tell if it is shot?
ok i just did that it go in fine....
it might be a 1 way bearing.. if it is would it do the same thing...?
Then try some other things, I would have to see it to be able to point you in a better direction.
Is your one-way bearing in the right way? Try cleaning the one way bearing and shaft with some DA or nitro cleaner then lube the bearing.
did that ... it can go on 1 way... on that motor.....
and the pull start spring broke today .. so i put on a roto start... and it still slips...
Yep, its the one way. If you cleaned it, and lubed it, and its still doin that, you need a new one-way.
where can i get 1 ? because it is a xtm motor it is hard to find part...
spy, you did it again. The link you need to look for parts is already posted above. You do this often, keep asking questions even after a link is posted for your benefit.
Revo Rancher i will check with them.... we are trying to re bend the spring on the pull start
spy, in case you were not aware, Hobbypeople is the importer for XTM products, so it might be rare to find their parts anywhere else. They do have good customer service and they have one of the best websites around.
thats where i got the new piston and sleeve... your right there are 1 of the best places to get stuff from.... i order the pision and sleeve and sent them a money order... and it came it came 4 days
