the xtm-24.7 book says the lsnv setting is 7.5 to 8 turns out from bottom, question, I have to set mine at 9 turns out to get it to start & idle 1/2 way decent but it blubbers alot till it cleans itself out, if i turn the lsnv in it dies & tries to start but only uses what priming I've done then dies. If I turn the lsnv in till it bottoms out the o-ring gets chewed up from going into the threads of the carb barrel, I've had to replace it once. It feels like the lsnv gets sort of tight when the o-ring hits the threads but I still have about 3 turns till bottom, hsnv is at 2-3/4 turns out, temp is around 250-F & I've changed glow plugs a couple times now its a Mcoy #8, no bubbles in the fuel lines, any help??? also when i bought my 24.7 the cushion spring that goes in the little hole on the hex-shaft on the pull start was in a little bag with the engine, not in the pull start where the drawing shows it to be, any ideas on it?? thanks for any advice, Robie6:constipat
