XL Arms on X
The XL arms and knuckle will fit no problem. The diffence is the XL/Flux parts were built a bit beefier with more webbing for strenght. I have the full XL outer set-up I am putting on my FLM extended Savage. It is a good upgrade.The only problem with the wider axles is you also need the heavier drive-shaft since the ends of the dogbone is larger and the diff cup side as well. I looked into it and ended up with the BP diffs and driveshaft and. and and....sigh so much for a cheap upgrade...lol
Well i already installed hpi's super heavy duty drive set with axles and diff cups, so should every thing fit?
Oh you should be good to go then! Just remember to put on a supercharger and the NOS bottle and you will be all set :p:! .....huh huh huh....I just said supercharger....
[SIGN]Nope..they still SUCK![/SIGN]
