Pics of my Revo and all the spares.
Clutches, flywheel, new OS head pipe, 2 diffs in good condition. Tons of Tranny parts.
Cirrus 3ch FM Radio system with manual, like new. Forgot to take a pic of it, sorry.
Tekno rear extended A-Arms with Ti. pivot balls and al. carriers.
RPM Tru Trac rear arms installed in rear, RPM arms in front with Ti pivot balls and al. carriers. Couple of stock arms, used.
THS exhaust installed, extra stock pipe included will work with OS header. Extra new header gasket, new glow plug for engine. some new bearings, some used but still good bearings. Tranny has 1/2 gallon on rebuild, everything was replaced in it. Slipper clutch is set perfect, no tranny problems. Center diff installed but the parts are there to put it back to stock.
lots of extra rod ends, pivot balls hardware.......
Tekno radio box and throttle servo mount. Mugen 160cc fuel tank. Stock fuel tank extra. the throttle servo installed is bad, but I left it so the new owner can see how the linkage is connected.
Integy al. rear skid plate, Traxxas wing mount and Carbon wing. Wing is a little rough but intact. Body is rough and has multiple mounting holes in it. But it is solid no cracks.
lots of other stuff, too much to list. Orion 1600mah battery pack.
You will need an antenna tube and two servo to complete it.
Engine has a roto backplate, a pullstart is also included. No roto start unit included due to I only have one and need it for my savage.
M2C racing clutch installed, best clutch there is for a Revo. Hits just like a 1/8th scale clutch, no clutch drag at idle.
I always burned all the fuel out of the engine and disconnected the fuel lines, i used ARO in it most of the time. Truck is stored inside my home always. Motor Saver Air filter plus two extra filters clean and oiled.
290 shipped in the USA.
Tires that are included, good condition. They are 14mm hexes. The 14mm hexes are included but ofna 17mmm hexes are installed.
