boilermaker13
RCTalk Rookie
I’ve spent over 2 hours trying to start my SS (stock .25 engine) but could only get the engine to turn over once for about 1 second. I have installed the header tank and tried starting it using the header tank and just using the main tank. I’ve sealed the back plate and carb. I'm using an OS #8 plug. I started with the HSN at 4.5 and the LSN flush with the carb body. The idle gap is about 1.5mm. I have the carb at about ¼ open. I'm using 20% O'Donnell and am pre-heating the engine to 150-170F.
I tried just about everything, loosened the glow plug 1/4-1/2 turn, tried adjusting the HSN between 1 turn and 6 turns. Did not touch the LSN. Nothing worked. I'm pretty sure my glow plug igniter is fully charged. The coil was bright orange. Should the entire coil burn orange - the coiled part and the straight part at the very end of the coil or just the coiled part? I’m thinking that my glow plug battery doesn’t recharge fully anymore. It’s a 1.2V at 1300 maH.
Any suggestions would be appreciated.
