Started up my savage for the first time this year, starts up perfectly but it wont lock into gear just sits there with the crank spinning. any help how to fix this would be apreciated.
if your flywheel is spinning but the trucks not moving sounds like the clutch is stuck. You'll have to take the engine out, take the clutch bell off and check the clutch shoes. Make sure they spring out and back in again. Is the spur gear spinning when you apply throttle?
if the engine is firing but the flywheel is not moving could be the small metal collar that goes between the flywheel and crank. Clutch and bell off and check that the nut that holds the flywheel on is tight.
