Transmission will not always make noise. If you snap the pin on forward gear it will not make any noise. Snapped mine a few times in the last couple months. I am told its from my slipper clutch being too tight. Only way to check is to pull it out and see if the gear spends freely on the shaft, it should not. Sucks if thats it because the only way to get that pin is to buy a forward only kit for the revo, or use a hardened roll pin like I did. If you have a stripped gear in the tranny it will not make any noise either, went through that last week. On a side note the only gears my lhs had were not the same part number the stock 3.3 has in it but it is a lot funner to play with than it was. It may depend on what you have in your diffs but if my earthquake loses an axle no power makes it to any of the wheels. When my rear wheel hex on my maxx stripped out last week I had front wheel drive but it was weak, like most of the power was getting wasted on the wheel that wasn't moving.
