wider tmaxx?
ىnap911
i want my tmaxx wider so it dont roll as easy on pavement. does anyone know if a company that makes extended Aarms? if so can you post a link?
Proline sells wheels that are 1/2 offset so that will give u an in more width also try harder oils and springs and lower your maxx
i have it as low as it can go. that helped alot. i figure making it wider will halp it handle much better
well like I said try stiffer spring and oils and
TRY HERE look at the bottom of the discription they will say 1/2 in offset
tmaxx as in older version or the newest version??
if the older then you will have to invest in the widemaxx arms and new axles and tie-rods and draglinks
if the newer version then lowering it and adding the offset wheels and even investing in the 40 series real wide tires and wheels
just my :2cents:
take care
rick
you can also add Hardcore extenders and use the offset wheels....BUT if you go too wide and low you still flip over....sway bars help when you do this to your maxx
all in all we still need to know which tmaxx you own ,either 1st gen or 2nd gen widemaxx
let us know thne we can further help you
