Who makes the T-15 engine?
what says T-15? i think my old traxxas said T-15 on the side of the case but I'm not sure, i may just be remembering wrong. if you're talking about something else then i dunno....
::edit:: well mine wasn't badged by hpi so it must not be a traxxas
T15 engine
Hi,
The T-15 is definitely developed and made by Novarossi, Italy.
almost all new HPI engines are designed and build by Novarossi.
You can trust these HPI engines to have a very good price and they are build with precision and in very large quantities.
the cylinder piston construction is ABC (which lasts longer than
Nicosyl cylinders, but they take longer to brake in)
If you brake this engine in correctly, you will have a longlasting, high rpm engine with nice power for a very nice price.
I only use NOVAMEGA (serpent) engines when racing (please note that NOVAMEGA are the most expensive engines in the world!), but prices on HPI/NOVAROSSI engines are a lot lower and you`ll have a very competitive, high-Q engine at low costs !
Quality,power and high rpm's of the T-15 and PRo series (XS) from HPI are pretty good for the avarage driver and club competition drivers!
SOME INFO :
FEATURES :
ABC construction
6mm Dual Needle Rotary carb
Side exhaust
Powder black case
Tall powder gray heatsink head (10 fins)
Aggressive porting
Standard shaft
INCLUDES: Glow plug, brass flywheel collet, air cleaner, instructions & decals
REQUIRES: Glow fuel and glow starter
SPECS: Carburetor: Rotary type, 6mm
Ports: 3
Weight: 10.2oz (290g)
Displacement: .15" (2.49cc)
Horse Power: 1.2hp @ 29,000 RPM
Bore: 15.0mm
Stroke: 13.6mm
Hope this clears things out for you!
Amirem
:banana:
