which size
MIP is the company that makes the CVD's for team associated. some of the kits use a 3/16" axle and others use a 1/4" axle. u need to determine that before buying. if i am correct - the rtr plus and all kits use the 1/4" and the old rtr uses the 3/16"
Where do u measure the size at. Is it were the bearings are?the shaft the that goes through the beaings?
its the diameter of the actual part that the wheel slides on to.
my advice would be to just get the larger 1/4" anyways. worse case senerio is that u need to drill out your current wheels a hair.
the rtr but i put a .15 cvr-x and the mip clutch. i also got the hitec hs-625mg steering servo and a rpm reiceiver box
is that the titanium chassi on yours
yes. and auminium shock towers. i also have the rpm box, and am running an OPS .15 in mine. lots of other hop ups too. i love it man. did u se it in my gallery?
i used to have a RTR ( u can see it in my old gallery pics) but recently purchased the factory team kit - which is what u are looking at now.
its pretty solid - i used to run it in my NTC3, but have since moved it to the GT and put an OS .15cv-r in the NTC3. although i like my OPS - stick with the OS mill's. i usually will only go that route, but tried something new and got a Rossi pixie black, and that OPS. the rossi is stupid quick but one of the hardest engines i have ever had to tune. the ops has been very reliable, 2 gallons through it already, but runs pretty hot (260-280) and doesn't have alot of low end grunt.
