Which Part # is this for HPI Savage 25
rcenth
I have the HPI Savage 25. Can somebody tell me which part # this is, it's the part that goes in the middle of the rod to hold the clutch bell in place.
Pic below - circled in red:
Thanks!
---------- Post added at 6:09 PM ---------- Previous post was at 6:09 PM ----------
Not sure why the pic didn't load, might take a minute but, here's the direct link just in case:
https://www.dropbox.com/s/a63razytp4wsz4g/2013-06-16 16.46.43.jpg
You can use small washers and a 3mm hex bolt. Washers are to take up space so bell doesn't shift forward.
Thanks for the reply. Is there anyway you can tell me which size washers? I'm a little clueless lol have a friend working on it for me.
Thanks!
Also is the measurement for the hex bolt 3 x .5 x 3 mm ?
The factory bolt is 8mm thread length according to my manual. The factory used a brass shim #86121 that is 5mm thick by 10mm diameter. I use steel shims as the brass piece usually wears out fairly quick.
Thanks! So about the bolt do I need to know thickness and diameter? Is it the same 5mm by 10mm? Sorry for these kind of questions, I probably sound dumb!
---------- Post added at 10:39 PM ---------- Previous post was at 10:35 PM ----------
Does this sound like it's it? HPI Binder Head Screw M3X8mm HPIZ517
Length: #160; #160; 8mm
Diameter: 3mm
