Wheels wont turn
screaminsavage
Today a crazy thing happened after I adjusted my shocks a little my front wheels wouldnt turn and the lhs said my stock servo was stripped , so I bought a 200 whatever expensive airtronics servo and he showed me while the truck was upside down how well it worked. But get this when I turned it over (wheels still off ground)
they would just barley turn like it was hung up. We sprayed it with air , cleaner, wd 40, and still no front wheel turning I even adjusted shocks back up that helped a little but when I turned the truck back upside down back and forth with power and speed very nicely but only when upside down !!! Now figure that out !! :argue: Its not servo because when truck is up side down it throws the wheels aroun a hell of alot better than the stock one ever did. All I have done to the truck latley is put on new purple springs like ss has and stainless steel tie rods??????
HHHHEEEEEEEEELLLLPPPPPPPPPPPPPPPPPPPPPP!!!!!!!!!!!!!
you have stripped the plastic servo arm set it on the ground and watch it does your servo turn?if it does than your arm is striped .replace and your good to go
did you use the same arm????
Yeah, check your servo horn to make sure it is not stripped. You also might want to check your tie rods. You could have some binding issues or they are hitting somewhere.
Later...:mex:
