Wheels aren't spinning freely
Matt King
I have a HSP 1/8 buggy
When I spin one of my back wheels, my two front wheels spin but my other back wheel will not spin.
Please help, I want to be able to run my buggy
I've checked all the pins,when I take off the back wheel it spins freely like all the other wheels, but as soon as I put the actual wheel on it won't spin
Sounds like you've narrowed it down to one wheel . check.the the pin behind your hub. Check your bearings or bushings. Sounds like it's over tightening and putting shaft in a bind. Make sure wheel is not Bent and that nothing is binding on inside of wheel.
It could have something to do with the hub or the bearings ,because when the wheel is tighten against the wheel hex & pin ,the
pressure of that ,should stop at the wheel hex & pin ,so that being said ,then the hub bearings are being sucked further past
the ridge or lip inside the hub that keeps the bearing in place , in which is probably broken down from over tightening the wheel!
I would say ,replace the bearing hub!....:thumbs-up:
