ozwes007
Can any one advise the ballpark for wheel allignment settings for a Nitro 1/10 scale SBR Falcon(Australian). Has Caster camber, toe settings for front and rear.
Currently I am running Negative camber on the front with 2mm toe in and negative caster. On the rear I am running Zero toe in and very little caster.
It seems to be very twitchy under acceleration and has a tendency to power steer right and left. Should I use more front drive or less. I am currently using 3% more front drive and it seems to steer better at high speeds.
