Is your collet in properly and is it the right one? Mine has plenty of room to spare.Nevaren said:perfect timing on this thread. Just got my werks clutch in for my Collari 30 motor. However... the 18 tooth clutch bell does not seem to be "long" enough for it. when i get it all assembled i can still see a bit of the clutch pads. It's almost as if the flywheel nut/clutch tension assy is holding it out too far. the brass bushing that was on my savage wont fit on the end of the shaft before i put the washer and screw in the shaft. if you have any pics of the assy on your trucks i'd appreciate it.
TIA
sweetdiesel said:For Racing , I would go with the rulon shoes. Rulon shoes make the clutch slightly more difficult to dial in becuase you need to make your spring tension adjustment to compensate for them heating up. For bashing go with carbon shoes, or a combination of 2 carbon and 2 rulon for more bite.
Warning, rulon shoes wear out VERY quickly, I've seen them last as little as 4 tanks, and stay away from water. Water + heat + rulon = chunky shoes.
Hope this helps.
