WD40 and silicone as after run lube, need info.
Has anyone experienced a failure that could be traced back to using WD-40? If it doesn't contain kerosene or silicone, what is bad about it.
Matt
Originally posted by PhillyB
taken from
http://www.wd40.com/Brands/wd40_faqs.html
What does WD-40 stand for?
WD-40 literally stands for Water Displacement, 40th attempt. That's the name straight out of the lab book used by the chemist who developed WD-40 back in 1953
While the ingredients in WD-40 are secret, we can tell you what WD-40 does NOT contain. WD-40 does not contain silicone, kerosene, water, wax, graphite, chlorofluorocarbons (CFCs), or any known cancer-causing agents.
WD-40 is the ultimate multi-purpose problem solver. WD-40 cleans/degreases, penetrates to loosen up stuck parts, prevents corrosion and is a light lubricant
WD-40 fulfills five basic functions:
CLEANS: WD-40 gets under dirt, grime and grease to clean. It also dissolves adhesives, allowing easy removal of labels, tape and excess bonding material.
DISPLACES MOISTURE: Because WD-40 displaces moisture, it quickly dries out electrical systems to eliminate moisture-induced short circuits.
PENETRATES: WD-40 loosens rust-to-metal bonds and frees stuck, frozen or rusted metal parts.
LUBRICATES: WD-40's lubricating ingredients are widely dispersed and tenaciously held to all moving parts.
PROTECTS: WD-40 protects metal surfaces with corrosion-resistant ingredients to shield against moisture and other corrosive elements
a LIGHT lubricant. leave it in the garage. it will attract dirt, only use when you are worried your parts will rust, like after a snow run or mud run. otherwise its useless to me.
Bah... liars :D
