Water cooling ?
as a radiator you should bend copper tubbing into like a inter cooler is on a car and mount in front of the body and get a tyler perry pump i thank thats what it is called and water cool it like that. just a thought tho
also i know that computers cpu fans are small you could use one to cool it off at the radiator and 9volts is plenty to run it
The radiator link I sent is a resevoir and radiator in one. You can hook a 120mm cpu fan up to it for more air flow. The more tubing you use to connect it all will give you more room for fluid.
Please wear protective OSHA approved breathing apparatus when reading this thread. It has been stored in the basement, under the asbestos insulated steam pipes since 2003.
Lmao never looked at the thread start date just thru my .02 in. Seems Avengedanarchy went dumpster diving and revived it.
