Wasp 28 Problems
NITRORUNNER
Hey Guys
I've Just Broke In The Wasp 28 With All The Usual Breakin Probs Youve Probley Heard Of.
Finnaly Got It Broke In However I can't Get It Tuned In Properly.
After The Initial Fire It Will Scream And Run Perfect Fo About 70 Feet When I Turn Around To Come Back The Trans Wont Shift And The Wasp Seems Like It Just Dies Unitil I Feather The Trigger.
When It Gets Back To Me At A Sitting Postion It Will Die Out With Trouble Restarting. No Overheating At All.
Can Anyone Help
Sounds like your HSN is too rich. How many turns out is your High Speed Needle and your Low Speed Needle? What kind of temps are you getting anyway?
I've Started My Hsn @ 4 1/2 To5 Out And Myln At 5 To 5/12 Ot
At These Settings It Would Idle But Die With Th Response
While Leaning In Down To 3 1/2 On The Hsn Resulted In Running But Dies Out.
Also Have A High End Pipe On
Ok, it sound like your HSN is fine (3.5 turns). I am currently running at 4 turns out on the HSN. It looks like your LSN is too rich. That's why you are dying when you sit idle. That will also make your acceleration bog out.
I am running my LSN at 3.5 turns out. Try leaning it out a little at a time and see if that improves your situation. Make 1/8 increment turn w/ the LSN and then do a couple of high speed passes to let the carb get adjusted. It will take awhile, but that should fix your problem. If not, then I have no idea what it is.
Thanks For Your Help
When The Temp Here Rises Above 20 Ill Try These Settings
