want to change easy start to????????
aaron1230
Is there a alternative to the traxxas easy start 2 system to start 3.3 Jato other than rip cord that leaves header and pipe in same spot
You can use a bump start (Starter box). You will need to change the flywheel to at least 38mm and will need a starter box.
Bump starts are great if you're a racer. It really takes out a lot of weight to your ride. The only problem is that you do need to keep the batteries charged.
