Reddog
RCTalk Champion
Well I bought a t maxx 3.3 used. Lots of aluminum and other "upgrades". Looked really cool. That is where the awe ends..... First issue, keeps stripping spur gears, found rear bulkheads where not tight and only one bolt left holding it on. That was fixed. Still stripping spur gears. Rats what now, the tranny only had 2 screws left in it, both on same side. Fixed. Spur gear problems aside now to get it tuned up. Got it close, kinda. This thing is so heavy that I NEED the engine running well for it to be a fun truck. With the tune off it is like pushing a snowplow through mud. Just cannot get it to tune in. Pulled the engine, resealed it and rebuilt the carb. Still cannot get it to hold a tune. It is also burning through glow plugs like mad (2 per tank). Found the header is cracked, order new one. Now I am starting to wonder if I got a good deal or not here. Because I did not drain the tank this time but rather just looped the fuel line from the bottom to the top. But it is leaking, crap need a new tank. Patterns on the flywheel tell me the front has a leak as well. Also noticed tonight that the front bulkhead has pop rivets holding the chassis to the bulkheads.
Now I am thinking total rebuild, get rid of the aluminum suspension arms, go with RPM. Big block engine, replace any bulkheads with stripped holes, and make a good fun truck out of it. What do you all think? Shaun
