upper and lower a arms
sciko_tc
how much are the upper and lower a arms, i live in a rural area and the nearest rc shop is an hour away, just anxious to know since i broke mine on both sides hitting a tree at full speed, and how long does the servos usuallyu last, i bought my truck brand new a week ago and its dead already, thanx
The stuff will last until you hit a tree.
Don't be surprised if there are other parts broken or cracked like the bulkheads. I suggest you take the front end apart and inspect all the parts for breakage.
Check towerhobbies.com or amainhobbies.com for pricing of spare parts.
You can get the parts numbers from the exploded views that came with your truck.
go to traxxas web site, order from there. i ordered two drive shafts on sun nite, got to my house today, tue a 2:00 pm. and my lhs did have it in stock on mon. but if i order something from my lhs he can't order it till mon. gets to his shop wed, IF its in stock. so in some cases you might be close to a week before you get your part. sometimes i order from my lhs and traxxas site, so i have a back up
a two thumbs up on RPM. some times its best to tap the hole for the shock mount bolt, before you put it together. i found that mine needed a longer bolt 3mm x 25mm long
