Upgrades
ch3no2junkie
Valdosta, GA
I have finally gotten all the bugs worked out of my tuck, and can actually make it to the end of a race without tearing something up. Now I want to work on getting some weight off the truck and improving the handling.
I want to go to a single servo steering setup as well upgrade to a high speed throttle servo. I was wondering what brand and model # other people were having good luck with.
I am also looking to ditch the E-Z start, has anyone tried the Hot Bodies jump start system? It looks very similar to an HPI starter.
Is anyone using aluminum rocker arm posts and rod end balls? I like the idea of them, I'm just curious about the durability of them. Thanks for any input.
Instead of a roto-start, most racers use a simple pull start and a glow igniter which shaves a bunch of weight. A good all around servo that i used on my Revo is the Hitec HS-5645 for steering. I also used one for throttle as well.
A high speed servo isn't really necessary for throttle, and if you get one that's too powerful your failsafe spring will be useless. I just bought a futaba s3010, it has 90 oz/inches and ball bearings. It is plastic geared, but for 24 bucks it works awesome. I did have a hitec 635 hb, which is faster, but it lacked power and had a tendency to give out when I hit the brakes. Also I couldn't use my stock servo horns as the 636 hb has different splines. I don't know if all hitecs are like that, but I'm just going to stick with futabas. My s3305's have been flawless for two years now, I like them.
The best way to trim weight off a revo is a pull start, forward only, Traxxas tubes, and aluminum pillow balls.
I like the idea of the aluminum turn buckles and push rods because they are very durable will save yourself a lot of extra weight! I went with it and never had a problem.
A true track would be good for the rear suspension too. You can save the cost of buying two more tie rods and never have to worry about breaking them either.
Are you talking about RPM arms?
For some reason, I can't bring myself to consider a pull start just yet. I think mostly, because I still bash with the same truck. For now anyway.
