noidle22
- Racing
hi, i've got a gs racing avenger which from the start has been a tool of a thing to use.
initially it was going well, broke in fine and ran well for months, then the front diff shattered and the steering servo broke. since then it's been an endless stream of problems.
i've attempted a retune multiple times but each time it gets worse and worse, this is probably my fault. it blows a ton of smoke and fuel under acceleration, if i try and lean out the HSN it has no apparent effect until it starts sounding terrible and doesn't back off revs when i let the throttle go. i followed the flowchart guide for tuning but it hasn't helped. it won't idle for even 10 seconds so i can't get it up to operating temperature to tune it anyway lately . if i hold the revs up it works but this's getting a bit tedious. i tried leaning out the LSN to improve my idle, this is similar to the HSN, it has no effect until it gets to a point where the car just wont start, if i richen it out again it'll return to idling for about 10-20 seconds.
if on a good day it wants to run and i put up with it blowing heaps of smoke and running poorly, it runs through about a quarter to a third of a tank then stalls. no matter what i try it wont restart. if i try priming it again the carb feels like it's got a ton of backpressure that's stopping it accepting fuel and the fuel line is full of bubbles, i can also hear a kind of bubbling gurgling noise coming from the carb at this point as well, i heard something about the fuel boiling in the carb?
the fuel tank has no air leak, there may be cause for concern where the line joins the pipe cos there's fuel residue around the nipple but it's always been like that even when it was running well. i will seal up the engine when i get a chance and see if that helps but as of now i really dont know what to do.
is there anything else i can do/check?
thanks, and sorry if this's in some other thread somewhere, i wanted a thread that contained all my random problems
