itsalifeworthliving
making this clear, as the other on-road forum thinks this is a 4wd buggy... this is a 5th scale 5b ON-ROAD..this is an ongoing problem that i could use some help with.. my butt comes around my head..serously. when entering a turn tha back end comes around.out of the hole shot it hooks up sweet. on power streering is great for a 2 wheel drive buggy. i dropped the back end down so its lower then the front, and use tire traction wich helps for a little bit.. should i lower the shock oil wieght or the shock piston.out of the 5 piston holes, I'm on the smallest 1(its hyper-adjust). but my front left tire comes off the ground as it is.. so if i go any lower, it will get worse. what if i put on a heavier spring? have many.. I'm set at 2* with my rear toe-in will a zero toe-in help.. I'm also running light diff oil. i think if i go heaveir it will be even worse.?. PLEASE.. any tips will help.. this is a 1:5 hpi 5b.. its all the same, just bigger
