militarymaxx
Not sure if these are on other buggies, but they're on my Storm.
On each swing arm, near the hinge pin, there is this set screw. It's not the one that secures the hinge pin itself from sliding out, I've identified that one. This one is larger in length and diameter. The manual id's it as 4X12 mm set screw. It can be adjusted all the way through the a-arm and this is what I'm thinking. Is it some kind of fine adjustment for the a-arm ? If I adjust it in enough it will eventually meet up with the chassis and this would keep me from over extending the shocks. Am I on to something or does it serve another purpose ? If I am correct, what is the proper adjustment ?
