Ultra shock set up.
pigpen
Hello all I am new to the board and new to 1/8 scale buggies. OFNA Ultra LX Pro. I realize that I bought entry level, but I bought what was available to me from a guy that was leaving Korea. Anyways, my Question
What shock springs fit the Ofna Ultra shocks? I bought a set of Kyosho springs, but the are about an inch longer.
Here are the symptoms. Throughout the day, our track gets more and more bumpy. The front of the car holds the track pretty well where as the back of the car bounces all over the place. Both the front and rear shocks all have the stock pistons and springs on them. I don't know what the fron oil is, but the back has 35 wt in it. What can I do to smooth things out a bit? Thanks for your time.
I am all the way up on the top shock mount, all the way out on the bottom shock mount, all the way up on the threaded shock nut. How do I go softer from there? I have done RC for a long time, but the shocks is one thing I never understood, and spent alot of time just guessing. But it takes a week or 3 to get parts here for me, so trial and error is out the window. Thanks again.
Straight up and down shocks is going to give you more bounce. Reposition the top of the shocks so you have more of a / \ angle look from the rear.
Softer springs would probably be the way to go. I wouldnt drop oil weight too much on a buggy. Not below 30 anyhow. You can also check to see if the stock pistons only have 2 holes. If so, swap them out for 3's. In fact, if they are 2's, just switch them up and change shock position before you go with new springs.
Thanks Çh®i§tiªñ What brand and color springs should I hand signal for? I have a major language barrier with the guys local at the track here in Korea.
:dance:
Good question - not certain on the OFNA shocks what colors equate to what. Ill dig around and see what I can find.
Yeah definately go with repositioning the shocks and check those pistons first.
OFNA's site SUCKED! trying to find out what springs fit what was not happening.......
check the editied post above, may help a bit, sorry, new to the nitro buggy scene.
Here are the part numbers and descriptions:
40069 - Spring Set, Black (stock)
40070 - Spring Set, Green (soft)
40071 - Spring Set, Blue (medium)
40072 - Spring Set, White (hard)
The stock pistons are 2 hole but I couldnt find 3 hole ones for those shocks. At least not the part numbers.
maybe I will try drilling the 2 hole ever so slightly bigger :)
Hey Çh®i§tiªñ, that worked out nice. The car was much smoother as the day wore on, not near as much bounce as the previous week. I lightened the rear oil from 35 to 30, drilled the holes to 1/16 inch holes, and that was only slightly bigger. I also took the bladder of the shocks, and there was a :censored: load of oil behind there, not allowing the bladder to do it's job. And yes, I did put them backl on. :) I know there are much better cars out there, but until I have one of those, this thing is cool. I love 1/8 scale, and in a little over 3 weeks, I will be back in the states where the language barriers are usually restricted to the accent of the area you are in :) Thanks again for you time and help.
Nope, Utah is the next stop in my career, but my wife is from NYC so we may end up east coast some day when I retire from the AF. Not NYC but somewhere out there.
I know you said you were not familiar with Ofna's but do all the 1/8 buggies have a steering block (limiter) on the lower arm? I need more steering, on and off throttle. I have to steer with the rear of the car in the tighter section of the track.
