Plaidfish said:you guys are funny....yeah lessen was following the info.....but the final drive ratio is another calculation...I forget what just the diff ratio would be called.....meybe "diff ratio"????Hyped you need to drink less beer it seems to me...or more depending on how it hits ya....![]()
Lessen said:oh. I always thought the final drive ratio was the common term for the differential ratio. Like in 1:1 you see stuff like 3.55, 3.92, 4.10 etc. So it just seemed like it was in that rhelm and it made sense.
Plaidfish said:![]()
these are what they look like...as you can see these will replace the diff housing (that ball looking case that's in between your bulkheads) and the bulkhead....no wthere is also a diff cup...that's inside the housing..it's what holds your spider gears, bevel gears & outdrive cups together......if you go to the 1/8 scale diffs you won't need to beef up the cup like a 10 scale set should be....you can use regular plastic 7.5 cups.....when you look at the cost of doing maxximizer or RRP and aluminum bulks / diff cups and the gear sets...this comes out way cheaper, is more durable & you are using stock parts from Kyosho or OFNA buggies.....IF you do ever blow one up the repair will be much less as well......do a flea-bay search for bulkless and you should find atomrc's version of these in th epic...he usually auctions th e10 scale version but I go ta set of 1/8 scales for 20 bucks more.....fastlane wants 180 for the set...I got mine for 125 shipped......then I found a guy in jacksonville had 2 sets of 7.5 diffs NIP for 45 shipped...outdrives were another 20.....so less than the UE diff gear set up I beefed up my whole front/rear end of my maxx and haven't blown a diff since.....I can't say this enough SHIM KIT SHIM KIT SHIM KIT.......you want them to spin as free as the y can but have the least amount of play.....
