It could be either, but if your trying to do wheelies then probally too lean. I had a hard time with my XL, temps were too high or rather higher than I had hoped. But if I kept it any richer than I could not get any performance so it's a fine balance. As far as wheelies are concerned, two things - first the spur gear tension may have to be adjusted. They say a half turn out from all the way in, mine was too loose. Second the stock pipe is crap, it restricts the exhaust too much, I managed to remove the baffle inside the pipe, took about 45 min but well worth it!!! IT'S VERY VERY LOUD, but a wheelie machine, and it runs cooler about 260 deg.
