Punisher
RCTalk Qualifier
- Thread starter
- #21
Here's my understanding of it, feel free to help me educate myself and others:
The hsn still controls the maximum amount of fuel the engine can get, the lsn is capable of delivering roughly 3/4 of that. The lsn is long and tapered in such a way that it can regulate that much fuel until the the slide opens up all the way and the hsn can make it's contribution.
Spot on.
It would be a lot easier to tune the long needle carb if you could start with the HSN and then go to the LSN . . . then you would know the range you had to play with - once in the ball park it would tune a little more like a short needle carb - the issue with this carb is that any tiny adjustment on the HS moves the LS.
I know what you mean when you say all carbs should have this metering system - whilst the long needle provides mid throttle metering (with the needle) which is a good thing, the needle also dictates the fuel curve which is a bad thing.
In 1:1 scale cars we have the SU carburettor - the fuel curve is dictated by the shape and length of a needle that pulls in and out of a jet - the amount the needle is pulled from the jet is dictated by manifold vacuum (not the accelerator pedal).
Much trial and error is involved to get an SU carb running nicely on a performance engine as the correct shape and length needle needs to be identified.
Once the needle size/fuel curve is correct they are a great little carb.
Another type of 1:1 carb is the down draft carb made by Holley . . . Rather than fuel mixture being dictated by one fuel circuit (controlled by a needle in a jet), Holley's down draft carb has individual fuel circuits - idle, transfer, cruise & power - each circuit is introduced in series as the throttle is opened - each delivers their extra portion of fuel on top of the previous circuit - each circuit can be tuned to deliver the correct amount of extra fuel required by the engine.
The short needle carb can be likened to the down draft Holley carb; but instead of having an idle, transition, cruise & power circuit, the short needle carb only has an idle and power circuit.
The issue with the RC long needle carb, is that it has the same problems as the 1:1 SU carb in as much as the length and shape of the needle needs to be correct in order to get the fuel curve correct . . .
What the 1:1 SU carb has working for it though, is the amount the needle is pulled from the jet (which controls fuel supply) is controlled by vacuum/engine demand, not the throttle - this makes the carb a little more forgiving.
I know a thing or two about 1:1 carbs, so yes, it is a little frustrating for me to be beaten by a basic (in comparison) RC carb - and like said, once set, I reckon the long needle carb would be a good little carb, but I just dont have the time, energy or necessary mental disposition to sort it out.
More significantly, I can’t afford to be making trial and error adjustments at a race meet.
A .5 hour or less adjustment on the HS will require the LS to be moved.
If any, are the performance benefits and/or fuel economy provided by a long needle carb worth all the stuffing around? In my humble opinion - no.
Thanks again for your comments - I hope this info can assist someone to understand and tune their long needle carb.
