STONER RC
Lifetime Supporter!
- Brick, New Jersey
- Racing
- Crawling
- Scale Builder
- Flying
- Boating
Hey don't know if your aware.. buy when done for the day.. make sure you run the tank empty.. till the truck dies. Then try and start it a few times.. till it won't fire at all. Then pull the plug out and turn upside down and try to fire just to make sure... then put you piston down to dead bottom center to and not up to the top of sleeve. You can just put it down with a wooden Dowell or plastic stick.. you don't want the piston at the top of its stroke...want it at the bottom... then you can mark the flywheel with a paint marker or a dremel grinding tool.. so you always know where bottom of the stroke is
