fstrchld420
For those of you who read this in the "welcome the new guy" thread...disregard...just figured I'd put this in the proper place and see if anybody else bites.
my revo was pretty much all stock except for a few suspension changes until I decided to change the stock air filter out for an aftermarket one. Its one of those that has the outer filter with the inner foam. Seemed to breath better. Then I went for the fun dual exhaust from integy. As hard as it was to try and break in the engine from the start without playing too much, I probably blipped the throttle a little more than I should have. I've run it pretty hard since and I've probably got 30 or so hours on the engine at this point. At this point its hard to start and hard to keep running when I do start it. I'm thinking its a mixture of temp changes here in washington, new air filter, new exhaust, and a possible loss of compression. I bought a new sleeve and piston but have yet to install it. Should I go back to stock pipe and air filter before changing out the sleeve and piston and the break it in like new again? Or should I break it in with the aftermarket parts installed? At this point, where should my settings be for rich/lean fuel, idle setting, etc.?
