Mr T-Maxx said:
Good stuff Plaid, but I'm not sure you answered the question or maybe you did.
Installing a low end pipe does or does not affect the top end? If so, How?
Thanks Again.
Mr T
Yes, it is highly likely that you will see a reduction in top-end power if you fit a low end pipe. This may be a good thing or a bad thing.
If you have an engine that is designed to give strong low-mid range performance and drive on a tight, technical track then fitting a low-end pipe and a clutch bell with more teeth is the way to go. Chances are that you will be pulling strongly out of the hairpins and will be half way down the straight before your buddys' screaming 8-ports have got on the pipe.
On a faster track you may lose out with this setup because the screaming engines have a higher top speed and will open up quite a lead on you on the long straights.
If you have an engine with more top-end than you can usefully put down on the track, then fitting a "mismatched" low-end pipe can tame this power, give you more tractability out of tight corners and reduce your fuel consumption into the bargain, maybe you will need one or two less fuel stops in those long A-mains.
Performance 2-stroke engines typically have a lot of overlap in the inlet and exhaust port timings, in theory the fresh inlet charge coming in through the inlet port can flow right across the cylinder and out of the exhaust port, the cylinder is never properly filled before the compression stroke and maximum power is never achieved. What the tuned pipe does is cause a reverse pressure wave at the exactly the right moment to push the escaping inlet charge back into the cylinder through the exhaust port. The engine is "supercharged" and the compression ratio and power are increased.
The length of the tuned pipe (and exhaust header) determines the engine speed at which the peak supercharging effect occurs. The width and taper profiles of the tuned pipe determine the intensity of the supercharging and the "power band" in which it occurrs.
