trx 3.3 bearing
diozxlive
what the bearing codes for the trx 3.3 front and rear bearings. i know that the front bearing is 697rs (please correct me if I'm wrong). we have a local SKF and NSK bearing around the area and hoping that it would be cheaper to get it directly from the bearing center rather than ordering it online... thanks...
The numbers I believe are what traxxas assigns to it. what you really need is the size. You will need the Inner diameter, outer diameter, and width and they will should be able to hook you up.
Boca bearings has a sweet set for $75.00 and TKO has a set for around $40.00.I can only get a gallon or two out of the stockers and the rear bearing is toast.If you don't catch it right away the engine becomes a paperweight once all the shrapnal goes through it.
thanks guys... but the shop apprentice have issues with the size. seems like he don't want to go thru the record books just to search for the bearing size, specially if I'm only purchasing few pieces. they always go with the stock numbers, like the front bearing is coded 697rs (rs for the rubber shield i guess). thanks....
found the code... 697rs for the front bearing and 6801 for the rear.... 3$ each..
