truckzilla big twin
vr6dub
england
Hello people I'm new on here, just got myself a big twin truckzilla truck of flea bay. the engines need breaking in but I'm unsure of what the factory settings are for the carb and i don't want to run it till i find them out! was hopeing to do that this weekend:)
I have tryed finding the info out on the net but had no joy, so hopefully you guys might be able to help me out?
Thanks Lee
If it's brand new, they should be at the proper settings now, and you only need to adjust them as you get closer to the end of the break in.
yes it has two .26 engines with Jump Start & Two tuned pipes with manifolds
The chap who i brought it of said he had run one tank of fuel through both engines, but i know how important it is with running these things in and just want to check it is set up right. haven't had one for a few years now so I'm a bit rusty!
at the moment the screw that adjusts the amount of nitro and air is flush, if you know what i mean? (turned out 5 turns).
Thanks
Most new nitro engines made are setup so that the factory settings are "flush" with the housing that they screw into, so I'd say you're probably quite close to where you want to be if thats the case.
Ok cheers just wanted to make sure!
