truck wont go
screaminsavage
I put reverse in my sav 25 and a 18t clutch bell last night. I ran it fo about 15 min today and then it just stopped moving it revs up but no motion, and oil spitting out of the pipe like its relly rich but its not? I dont run it that rich. I havent used reverse yet because i havent completed attaching the servo I just have that u shaped pin around that thingy and through the holes but not fastend yet . Anyone with rev will no what the u shaped pin around the thingy is :deadhorse . I guess I should tear back down and see why no movement when giving gas , if you roll the wheels forward the all catch and move . I just can't get the spur gear to respond to the throttle I guess is what I'm trying to say but why did it work earlier ?:puke:
i had same trouble, car would run for about 5 mins then it would just sit there revving its nuts off. Never did find out what the problem was but i took the reverse module back out and never had any trouble since. can't say i miss reverse at all
I found out what it is the small pin that the wire from servo hooks to has to be all the way in or out . If its not it will sit in a neutral position some where in between . Sero has to be set just right !:sheep:
