My S25 has 3 quarts through it and it runs very good. I think my tuning is good because it runs without hesitation, it sounds clean, it blows smoke, and the temps are reasonable. The compression feels very good.
I am able to get it started pretty easily when it is cold. I loosen the glow plug slightly, prime the carb by blowing into the pressure line until the fuel hits the carb, put on my glow igniter, manually open the throttle about ½ way, and start pulling. It usually starts to kick after about 2 pulls and I can get it running after a few more pulls.
If I try to start the motor when it is hot I have a lot of problems. When it is hot the compression is a lot less so I do not loosen the glow plug. I make sure that the carb is primed and I pull and pull and I get nothing. I do not even get a kick. When the engine cools down a bit (about 10 minutes) and the compression goes back up I am able to get it started again.
I have never been able to restart it when it is hot. I’ve tried playing with my throttle opening while pulling, I’ve tried priming it more to the point of flooding, and I’ve tried clearing the engine of fuel (remove plug, turn upside down, pull a few times). None of this works. The only way I am able to get a hot engine restarted is to let it cool down.
Is there a trick to restarting a warm engine?
