Traxxas ESC reversed
Zerksies
RCTalk Champion
Brick, New Jersey
I have a latrax Teton that I am putting back to stock for my son. He has a spectrum dx5 with a sr315 receiver. I put the stock ESC and motor back in. But it seems to go faster in reverse. How do I factory reset the ESC? Calibrating isn’t working I can’t get it to blink past one to switch to reverse
I've had the same issue on similar platforms but I can't recall what I did to fix it. Seems it was a matter of switching motor direction in the esc settings. Haven't had enough coffee yet. I'll get back to you in a cup or 2.
That does not fix the speed issue. It's faster in reverse then going forward
Have you tried it?
I honestly forgot to mention the changing wires on the motor also like @nino mentioned.
The stock Traxxas Latrax Esc and motor are brushed and both are color coded red/black.
I think the fix is in a transmitter setting.
Worst case scenario the red/black motor wires could be reversed or swapped.
(The esc does have a training mode)
in training mode rev will never be faster than forward.I think wires got switched in reinstallation on esc and motor.. Thats the only thing that makes sense in a brushed system
post a picture of motor and endbell with wires attached
Can't you reverse motor direction in esc?
Traxxas ESCs aren't programable like that. That's 1 reason why I don't like traxxas electronics. They only have 3 throttle profiles to choose from and no actual settings like motor direction, lvc voltage, punch. All of that is preset and can't be adjusted :(
You could flip the wires around to flip the direction though. But only on sensorless setups (for brushless) and brushed.
True. But the Tx/Rx tells the Esc which way is forward and which way is reverse.
Yea the hobby wing esc is nice. Pretty sure it comes with a old Tamiya plug which I would snip off and solder on a Traxxas plug. Been thinking about getting one for my Mini B
I've never seen anyone put a Traxxas connector on something. That's the first thing I do with a new Traxxas, snip snip.
True. I only said that if OP uses traxxas batteries. But if not, I would prefer Deans, XT30s or EC2s.
