Traxxas 3.3 optidrive transmission into 4910 t-maxx
WazabiQc
Quebec
So i was wondering if it would be hard to fit ? As i'm new to the hobby, i don't want to get into deep mods, but would that mod be mostly bolt on ?
It should fit right in. The 4909 model was actually a 4910 model with the addition of a 3.3 engine,
resonator pipe and Opti Drive transmission, 3.3 axle hubs and axles.
The 4909 pdf should help with any additional parts you may need.
http://traxxas.com/sites/default/files/4909_explodedviews_front-2007_0.pdf
http://traxxas.com/sites/default/files/4909_explodedviews_chassis-2007_0.pdf
http://traxxas.com/sites/default/files/4909_explodedviews_rear-and-shock-2007.pdf
http://traxxas.com/sites/default/files/4909_explodedviews_transmission-2007_0.pdf
The 4909 trans is pretty much a direct fit, it uses the same 5mm input shaft and is the same length as the #4910 black trans. The newer style #4907 trans has a 6mm input shaft and is longer and uses the revo style brake setup. Hope this helps. The black trans is every bit as strong with the FOC installed. I have run both in highly modded big blocks both held up about the same.
