Traxxa revo
Lisa78
Bronx, New York
I would like to purchase some new tires for my revo. I WANTED TO KNOW WHAT SIZE TIRES FIT MY TRUCK AND ALSO, WHERE CAN I BUY SOME HOT PINK OR PURPLE RIMS. I BEEN LOOKING BUT I can't FIND ANY. DO YOU GUYS RECOMMEND A WEBSITE
THANX
As far as a tire "size" - They will all fit your truck. You just need to make sure you have the right size hex for your hubs. I dont own a Revo but think 17mm. The hexes are interchangeable for the most part as well if you wanted to go even bigger.
As far as rims I know RPM used to make purple chrome 1's but I can't remember what the rim was called. You could look into buying a set of white rims from rpm and dye them using rit dye. That way you can go for whatever color you want
I have owned a few Revos and your best bet is go with a 17mm hex and get the aluminum ones. As far as tires that is a personal preference but the pic below is 3.8 RPM revolver wheels and 3.8 Proline Badland tires. You should be able to find everything you need at http://www.amainhobbies.com
70946[/ATTACH]"]
70948[/ATTACH]"]
Thanx i like ur wheels on ur truck i will def, check that website out. By the way whats the name of the part protecting the center of your engine? That silver metal piece? I would like to buy one as well, cuz driving my car, at times it does flips and what not and i wanna protect it? Please let me know so i can purchase it tomorrow
thanx sypone
Thanks It is an RC solutions cage, I got rid of the Revo a year or so ago but the website is here you can find cheaper roll cages but you won't find a stonger one.
A pic with the lid off
70952[/ATTACH]"]
The cage is more for extreme abuse like this
[ame="http://youtu.be/7d3WS1_gAL0"]http://youtu.be/7d3WS1_gAL0[/ame]
Also the trouble with the cage is you are limited as to what bodies you can use, I had to chop that truck body up allot to make it fit.
Home movies:)
70954[/ATTACH]"]
Mud bogs.
70956[/ATTACH]"]
heres my cage i built myself. cost me $10 of steel and a good avo or day depending how efficient you can work. i built it specifically so i can remove everything as if the cage isnt there so i dont need to take it off.
