Savage Beast
After running over 3 gallons of fuel through my Savage, I thought I was going to be exempt from the notorious "tranny set screw problem". But NO... it finally happened. No second gear and the truck's wheels will only roll foward. I took the tranny apart and found where the set screw had loosened itself up. When you tighten this back up, I know to use threadlock, but do you tighten it as far as it will go? Or is does this screw have some sort of adjustment?
