Transmission question
Slayer is geared a bit higher. Easily fixed by running a smaller pinion if you want to adjust that. They do share the same center diff. And rear brake kit though.
Sent from my SCH-I500 using Tapatalk 2
haha you seen them for $20 too,i nearly bought one for the slayer build but I've already got 2 sitting here lol
The slayer tranny is geared considerably higher than the Revo is.
The slayer 1st gear ratio is comparable to the Revo 2nd gear ratio.
It would be hard to find a clutch bell and spur to fit the Revo that would make up the difference in ratio (if you were trying to get it close). It would be best to swap the Revo primary forward and output gears into the slayer if looking for a similar ratio.
Center diffs between the two have different tooth count/ratio.
well i was just lookin for a trans for my revo for cheap. Plus i didnt want to pay the extra money for the reverse and just pull it right out!
