transmission help
DMAN_123
So I had a .15 engine and everything was fine with the transmission. Then I upgraded to the 3.3 and now the transmission will not shift into second gear. Any suggestions on why the trans will not shift?
Once you have a good tune on the engine, the trans should shift for you.
+2 on the tune you definetly need a good tune!!! when there is a good tune and you get secound gear to work... you will love it!!!
reset the cardto factory settings and see what happens from there
